Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-21-2009, 08:30 PM   #1
gas oven isn't heating
anyone have any advice on this? My oven is not heating properly. It took 30 minutes to get to 175 degrees. I checked and the igniter came on and seemed to burn a hot color but I smell gas like for some reason the gas in the burner is not burning. Could the burner be plugged not letting it light correctly? The top burners work fine and I hate to replace the stove. The smeel of gas does scare me though. Any help would be greatly appreciated
deerhide is offline   Reply With Quote
Old 06-22-2009, 08:42 PM   #2
Check oven safety valv in oven.Same prob here. It was bad would not light but leaked gas. Pretty easy to remove and mine $100. Check repair.com or other with model #. Or just take pic and compare...Good luck. BTW turn off gas b4 doing anything and unplug appliance.
Han'D' is offline   Reply With Quote
Old 06-24-2009, 04:16 PM   #3
Smile
Thanks for the info Han. It turned out it was the ignitor. It wasn't heating hot enough to totally open the gas valve so for $63 we replaced it. Found out they are very easy to replace. Thanks for your reply and if anything else happens you have given me another area to check.
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Oven Blew Up at Connector with Element cynthiap Appliances 5 11-26-2008 07:30 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
