Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-17-2010, 11:57 PM   #1
Do something
D'Brie's Avatar
Question
Gas oven does not get hot enough
My Kenmore oven will not get up to the highest temperature (550 degrees). The burners are fine but the oven gets to 300 degrees maybe. Any ideas folks? I have cleaned it but no change in temperature. If it were electric I would change the elements. Thanks everyone.
D'Brie is offline   Reply With Quote
Old 09-18-2010, 12:54 AM   #2
Does it act as if the temperature is satisfied (burns for a while and shuts off)? If so it must be the thermostat. If the burners keep burning but the temp never exceeds 300 then it must be not enough gas flow (low pressure, blockage or valve not opening enough)
The Following User Says Thank You to jogr For This Useful Post:
D'Brie (09-18-2010)
Old 09-18-2010, 08:32 AM   #3
HVAC / Plumbing
Sometimes ,If the iginitor is going bad it will cause this.. Ignitor not keeping the valve oper long enough to get to temp..The valve will list the amp draw. You will need an amp meter to check this... If ignitor checks good .. Thermostat
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
D'Brie (09-18-2010)
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Oven Install and Replacement- Dacor $400 CostcoMan Appliances 1 05-24-2010 07:02 AM
Gas oven problems gregsmy Appliances 1 12-03-2009 06:55 AM
Counter top trim to fit with slide in oven bhagey Appliances 1 07-17-2009 09:32 AM
Oven Blew Up at Connector with Element cynthiap Appliances 5 11-26-2008 07:30 PM
