Gas Logs - Appliances - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 10:14 AM   #1
Gas Logs
Pilot light goes out when I release the button to turn on logs.
I have vacuumed the area around the pilot light.
I have inserted a wire approximately two or three inches into the line to clear the line.
GAnge is offline   Reply With Quote
Old 11-08-2010, 07:17 AM   #2
there's a lot of safety issues with these so you should have a certified fireplace tech look at it...the thermacouple safety isn't sensing enough heat from pilot flame for whatever reason that's why it's going out..it may be just a dirty pilot but a tech can make sure it's at least safe especialy if it's non-vented type.
Jacques is offline   Reply With Quote
Old 11-08-2010, 08:44 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
needs a new thermocouple, probably best left to a pro
hardwareman is offline   Reply With Quote
Logs landing on a septic tank gma2rjc General DIY Discussions 3 06-05-2010 06:10 PM
Log Cabin Sealants??????? I suck at DIY General DIY Discussions 1 09-30-2009 04:27 AM
New Ventless Gas logs in an old chimney. Now how to block the chimney? keyser soze HVAC 4 03-02-2008 06:07 PM
Chimeny Liner Tbuddy General DIY Discussions 7 05-03-2006 12:27 PM
