Gas Line To BBQ - Appliances - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 06:41 PM   #1
Gas line to BBQ
After 8 years of BBQing on a crappy little propane BBQ, I noticed today that there is an existing gas line from the house, ready to go! It looks a little rusty.
How can I test to be sure it works and is safe before I go out and buy a gas BBQ?
mauxjen is offline   Reply With Quote
Old 09-08-2012, 06:48 PM   #2
Rewards Points: 13,740
Post a picture.
It's most likly rusty because it's suppost to be black iron pipe. Someone just never painted it to prevent the rust.
Is there a shut off valve on it?
Old 09-08-2012, 08:20 PM   #3
Rewards Points: 83
Why buy another BBQ when you can just convert your existing propane to NG. All you need is new orifices and a regulator.
Protocol. is offline   Reply With Quote
Old 09-08-2012, 09:04 PM   #4
DIY staff
Rewards Points: 7,174
Dig it up and look----it takes a long time to ruin black iron---
Replacing the line is well within the scope of a person with common sense and reasonable mechanical skills---
Old 09-08-2012, 10:06 PM   #5
Try posting some pics. Rust is pretty normal for black iron outdoor gas lines, even when painted. Most gas lines aren't painted well; no primer, just a few quick shots of tremclad, etc. If you want gas lines to really last, use epoxy. I try to primer and use multiple coats where ever possible when I install.
If it's an underground gas line like another poster suggested, I wouldn't use it. Black iron pipe cannot be buried unless coated properly, and paint is not a proper coating. If properly coated, you wouldn't see the pipe, just the coating, which would be a specific type of tape or mastic.
Also, another poster suggested converting, but you described your grill as not being in the greatest condition. I would invest in a new grill, already converted. They are usually $25-50 more than a propane grill, but would save you the hassle of changing the orifices and regulator, or paying someone to do it for you.
hvac benny is offline   Reply With Quote
Old 09-09-2012, 09:54 AM   #6
biggles's Avatar
is the line capped,is there a shut off inside the basement controlling the line...outside is paintable if it isn't capped bugs and things like the gas odor the seasons weather over 8 yrs....if capped your good on the run out
Old 09-16-2012, 06:45 PM   #7
Bombastic Idiot
notmrjohn's Avatar
If line is capped and not leaking and valve nearest gas main is open, your pipe is OK. I'd wager that if you hire pro to check it, first thing he'll do if capped, after visual inspection is just open valve and check for leaks. maybe with sensor maybe with soap.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Complete blockage of main line mnp13 Plumbing 9 05-29-2012 10:51 AM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
