Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-25-2009, 05:33 AM   #1
Talking Gas leak on new range installation
After installing a new range I cannot stop a slight gas leak at the regulator connection. I have the fittings very tight but still have a slight gas smell/leak. I tried tape on the flared fittings but still have a leak. I was told not to put joint compound on internal flare fittings so I have not tried that. Suggestions please.
beamerman is offline   Reply With Quote
Old 10-25-2009, 09:40 AM   #2
Hi! First question-Did you install a new flexible gas line?
First of all tape or pipe dope MUST NEVER EVER be used on a compression fitting.
The threaded nut pulls the smooth surfaces together for an air tight fit. Any thing on the threads will hinder the process.
Re using an old flex line with a new nipple some times fails-The flair in the flexline must compress against the rounded nipple. Often the flair on a used line is to mashed to re form itself to the new nipple.
I hope this helps,I haven't had enough coffee to think clearly yet.Good luck--MIKE--
oh'mike is online now   Reply With Quote
More On This Topic
The next step is to install the flexible gas flare fitting on to the male flare. So we basically place this on to here. Spin this and get the threads lined up nicely and then were not going to tighten this up all the way yet because we?re going to need... Read More »
Ok, so on the new oven on the new stove, the gas inlet is here. So that's where the gas is going to go in and then it goes into a regulator and then goes to the valves and to the burners. So we're going to need the fitting which will go into this, this... Read More »
In this clip we're going to talk about the proper way to change your oil in your rear differential. In this step we're going to talk about the proper service procedure for prepping our fill plug in the actual installation of it. What you're going to want... Read More »
Hi my name is Mark Delgado with American Auto Service for Expert Village. When the high pressure refrigerant leaves the compressor it will leave the compressor through a line. This is a manifold line assembly. It will be the high pressure side as the... Read More »
Ok, so now we have the threads coated with Pipe Joint Compound, and making sure there are no pieces on the interior and also that our, our female threads are clear. Which I'm pointing out here. These are the male threads, these are the female threads... Read More »
Installation of range hood vent duct. gante Roofing 5 03-09-2009 12:36 PM
Gas pipe to a gas range... matermark Appliances 0 01-27-2009 01:50 AM
range fan installation question Jeremy Hillary Boob, PhD Electrical 3 01-15-2009 06:06 PM
Range hood installation, termionating at ceiling gorf Appliances 3 12-04-2008 11:28 PM
Propane installation for range in kitchen acoustic_bum General Discussion 1 02-14-2007 11:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
