Gas Heat Pump - Appliances - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 06:30 PM   #1
gas heat pump
i have a carrier gas heat pump and it was working fine until we turned off the gas and repaired the line, my stove is also gas, and it works fine, is their something i need to do to make it work it will run but no heat now
tammyc is offline   Reply With Quote
Old 09-16-2012, 08:27 PM   #2
Bombastic Idiot
notmrjohn's Avatar
What repair did you make to line? Which line? and why? What do you mean by "running?" Fan but no heat? If it is not something real common like not turning gas back on, you didn't reconnect something, knocked a connection loose, or a problem with ignitor or burner. Is gas flowing to burner? Is ignitor working? Is there any flame at all?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-16-2012, 08:53 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
did you bleed the line at the heat pump. maybe just air in line. If this is not the fix to your problem go to HVAC and ask your question.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 08:06 AM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 09:13 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
