Gas Furnace/Air Conditioner - Appliances - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 09:45 AM   #1
we replaced the furnace and put in central air 4 yrs ago when we purchased this house. We are putting a addition on our house and we are wondering if we need to upgrade the furnace and air?
Our furnace is 90plus high efficiency furnace 75,000 and the air is a 2.5 ton?
Kittyangel is offline   Reply With Quote
Old 10-14-2010, 11:33 AM   #2
I have a comfortmaker 90 about 10 years old red light blinks 4 times fan come but does not light help please
yerry is offline   Reply With Quote
Old 10-14-2010, 11:45 AM   #3
You would get more responses by posting this in the HVAC section.
SKIP4661 is offline   Reply With Quote
Old 10-14-2010, 11:57 AM   #4
fabrk8r
fabrk8r's Avatar
Kittyangel, the only way to know if your system has enough capacity to heat and cool your addition is to have you or someone else do a heat load calculation on your home. Anything else would be a wild guess and you and your family probably wouldn't be comfortable.
yerry, look at the inside of the access door on your unit. There should be a chart in the wiring diagram that tell your what the trouble codes are.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 06:07 PM
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 05:58 AM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 06:31 AM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 11:50 AM
