Gas Or Electric Dryer? - Appliances - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 02:30 PM   #1
Gas or electric dryer?
Need to get a new dryer, what's more cost efficient and dries clothes faster? I can to go either way, as the current one is electric, but there is a gas hook up available in my laundry room.
Also, is there a way to convert the dryer from gas to electric or vice versa? Or do I have to buy one or the other? (I realize this is probably a stupid question, but my wife is making me ask anyway )
g_money is offline   Reply With Quote
Old 06-20-2013, 02:43 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
You have to buy the dryer as gas or electric. No way to convert them.
Unless gas is real expensive in your area and electric cheaper (helps to have your location in your profile)...gas is by far cheaper. Drying time will be the same. You can only get the clothes so hot with out causing a fire or melting the polyester.
One note...gas dryers are typically more expensive to buy...usually about $75 more...but are cheaper to run.
The Following User Says Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (06-25-2013)
Old 06-20-2013, 04:55 PM   #3
Roofmaster
Rewards Points: 2,172
Gas, Hands down. I will add to this that a front load washer decreases drying time by about 2/3 due to their high spin speed. Mine spins at 1500RPM in hi. As far as I know, no top load does this.
No you can not convert the electric. At least not for less than the price of a new gas dryer.
Old 06-20-2013, 05:13 PM   #4
MarginallyQualified
Rewards Points: 2,464
Gas is the best choice for everything: water heater, furnace, stove, dryer, etc. Everything else is make do.
Old 06-20-2013, 05:16 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 816
Side note....in California you can no longer install electric resistive heat in your house....has to be gas or heat pump.
Old 06-20-2013, 05:41 PM   #6
Roofmaster
So heat pumps cant have emergency heat then I guess huh? You know the toaster strips?
Old 06-20-2013, 05:42 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 816
Good question...I guess they can...I'm thinking that the wording is something to the effect of "Primary Heating"...
Old 06-20-2013, 06:35 PM   #8
chitownken's Avatar
Rewards Points: 510
Electric is better for ovens, as you can better control the airflow. Gas is better for the cooktop, but induction is close. Dual-fuel stove? best of both worlds.
chitownken is offline   Reply With Quote
Old 06-25-2013, 09:35 AM   #9
Rewards Points: 274
Well the You can alone get the clothes so hot with out causing a blaze or melting the polyester.
alexjoe is offline   Reply With Quote
Old 06-25-2013, 12:09 PM   #10
Rewards Points: 6,652
Yes, it is called selling which ever one you have and purchasing the other. Some people purchase gas because it is lower in costs, than electric in their area. I am lucky to be in an area that both gas & electric are low, so you see a mix of the two types being purchased.
It is really up to you which one you purchase. The deciding factor being cost for the utility that you plan on using to run the heating portion.
electric dryer electricac connection evetsnagorg Electrical 2 03-29-2013 04:32 AM
Electric dryer fire prevention Know It ALL Safety 2 12-08-2010 09:53 AM
Gas Dryer and Electric Washer amp demands mvmposton Electrical 2 02-05-2010 10:37 AM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
