Gas Dryer Wont Start - Appliances - DIY Chatroom Home Improvement Forum
Old 07-06-2014, 03:21 PM   #1
gas dryer wont start
ge gas dryer not starting. beeps once from panel and one click from board on no heat and two clicks from board on any heat setting. door switch tested fine with ohm meter. timer starts and counts down but motor will not run. wife ready to buy new one but this one is only 8 yrs old. any help appreciated.
texans43 is offline   Reply With Quote
Old 07-06-2014, 03:55 PM   #2
(the original)
Rewards Points: 756
Thermal fuse is the most likely suspect.
ratherbefishin' is offline   Reply With Quote
The Following 2 Users Say Thank You to ratherbefishin' For This Useful Post:
jmon (07-06-2014), texans43 (07-06-2014)
Old 07-06-2014, 07:15 PM   #3
Rewards Points: 342
As you have stated, door switch already tests good. Usually the thermal fuse (safety device) is the next thing to check as ratherbefishing pointed out. Go from there.
If no results there, click on link below for additionally advice/suggestions. Link also provides parts testing/installing videos. Just type in your model number of your dryer first. Just a suggestion.
gas dryer will not start
jmon is offline   Reply With Quote
Old 07-07-2014, 08:05 AM   #4
Rewards Points: 137
Can't help much without knowing dryer model number. GE does not use thermal fuses in their dryers.
thefixer56 is offline   Reply With Quote
Old 07-08-2014, 11:13 PM   #5
(the original)
Rewards Points: 756
ah...didn't know that...so is there a safety of some sort built in to the high limit stat? I know they're required to be fused in some fashion. I'm curious now because I have a GE gas that's about 15 yrs old and so far I've only had to replace the slides. The age has me expecting problems before too much longer.
Old 07-09-2014, 07:13 AM   #6
Rewards Points: 137
As far as I know, there aren't any thermal fuses in GE made dryers. They use safety and hi limit thermostats that automatically reset when the temperature drops to their cut-in point. I've just perused various GE dryer service manuals and wiring diagrams and don't find any one time thermal fuses mentioned or shown on any diagrams.
Old 07-09-2014, 07:07 PM   #7
Rewards Points: 14,290
Need the model #.
Old 07-09-2014, 09:19 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 2,110
Have you made sure the heat setting is not set to fluff?
ddawg16 is online now   Reply With Quote
Old 07-10-2014, 09:51 AM   #9
Rewards Points: 137
"one click from board on no heat and two clicks from board on any heat setting"
Problem isn't that dryer won't heat, it's that it won't start (motor won't run). Heat setting has nothing to do with that anyway. Motor should run regardless if it's set to air fluff. Again, can't be of much help without model number but I think the OP has left the building. Probably bought a new dryer by now.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Dryer tries to start but doesnt Redorchid Appliances 3 08-20-2013 10:50 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 02:35 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
