Gas Dryer Not Drying - Appliances - DIY Chatroom Home Improvement Forum
Old 05-14-2009, 12:27 PM   #1
Our gas dryer is not getting the clothes dry. I think the burner is coming on, the inside of the dryer is warm, but not hot. I unplugged the vent pipe (which had a lot of lint in it), but unfortunately it did not fix the problem.
Any ideas of what to do next.
Dryer is KitchenAid model KGY700GQ1
Fleener is offline   Reply With Quote
Old 05-16-2009, 11:39 PM   #2
HVAC / Plumbing
Is the dryer short cycling ?? There is also a moisture sensor that can go bad.. Coils on top of the gas valve will also go bad.. They may hold the valve open 1 time & may not open the gas valve the next time.
kenmac is offline   Reply With Quote
Old 05-17-2009, 07:21 PM   #3
I took the whole thing apart and cleaned the inside. Then started it up again. The flame comes on once. Runs for quite a while then goes out ( I assume because it has reached temp and the thermostat shut it off). After that it does not come on again. I can see the ignitor glow, but the gas does not come on. Does this mean it is short cycling? Solenoid is the problem?
Old 05-17-2009, 09:09 PM   #4
HVAC / Plumbing
While it's hard for me to diagnose your dryer from where I sit.. It sounds like the solenoids on the gv.. This is a common problem with gas dryers that are several yrs old
dryer not drying determined1 Appliances 5 04-07-2009 10:09 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 05:26 PM
Frigidaire dryer DIY repair CowboyAndy Appliances 15 01-21-2009 07:17 AM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 09:16 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 11:45 PM
