Gas Dryer Frigidaire
Frigidaire Dryer crcg5700as1. Changed felt & glides,changed bearings.Felt in back of drum looks burnt. Loud scrapping noise by back of drum after drum warms up. Also sounds like noise is coming from behind dryer by motor. Facing dryer left side back of dryer gets hot. I really don't know what else to do. When I take the drum off everything seems to work fine. I cannot keep it going very long with the drum off due to not having air only. Mine I put on low heat and let it run for a while and it seemed motor and fan and heat all were fine.
That noise starts out soft but as the drum gets warmer and warmer the clatching noise gets louder and louder. Is something behind the drum where the heat shield is maybe bent. So confused cause scrapping noise behind drum left side and noise by motor also. |
Gas Dryer Frigidaire Loud Noise Help Please
I have a Frigidaire gas dryer crcg5700as1 which started with a noise and gradually got louder and louder. Replace the bearings in the back and put in new felt and glides in the front. This did nothing at all. Same sounds possibly coming from motor area like a clatching sounds that gets louder and louder. Rubbing sound from behind drum on left side facing dryer. Dryer felt in back by heat shield looked like it was burnt. Vacuumed everything. 6 in family and really need dryer to work. Dryer works fine for about 3 - 5 minutes, turns, heats up, then it starts this noise which increases and gets louder. Drum turns, air flows out at vent outside. I can turn drum by hand with a little resistance. Really need someone to help me on what else I can do PLEASE.
Make sure you don't have the drum in a bind. Other than that ..Possibly bad motor bearings
did you put front glides in with teflon overhang facing towards drum? noise may also be coming from a cracked blower or blower hse. after it heats it expands and causes a noise. sometimes hard to see. pull drum and run mtr to try to determine source. only couple things will cause this.
just saw this 2nd post.. is the drum fully seated in that rear cup? when you pull drum you should see scrape marks if it's hitting. nothing else try to adjust legs. the dryer may be out of square. it's a pretty flimsy unit and easily knocked out of square.
I put the glides in with them facing the drum (back of dryer) |
no scrapes on dryer=not hitting. if belt were slipping drum wont turn with clothes load. belt inst correctly? rib side down?? from the rear access-watch idler while dryer running-ok?? ..with top in up position run dryer and see if you can determine source while observing drum while it rotates.
Doesn't mean it's correctly installed. When you load it with wet towels & tries to turn.. It could possibly be the motor. When bearing goes if it's not caught in time it can place alot of undue strain on the motor |
Got the motor but I cannot get the fan off of the motor. It just won't come off? ANy ideas how to get that off. I have tried everything.....that piece of plastic 7/8" hex is attached to the fan right? The whole thing should come off but it just won't budge. |
| All times are GMT -4. The time now is 11:35 PM. |
