-   -   gas dryer (http://www.diychatroom.com/f47/gas-dryer-34926/)
agrace 01-02-2009 03:35 PM
gas dryer
I have a gas dryer that does not seem to be working right. The timer and tumbler work fine but there is very little heat. I have checked the filter and washed it and made sure there isn't any lint in the exhaust line. This is 13 years old, is it worth fixing and if so is it something I can do??
Thanks for any ideas
Winchester 01-02-2009 05:28 PM
I'm just a DIYer and though I've recently taken apart my dryer (replacing the igniter) could only foresee that you would have a burner issue. Make sure that there are no air obstructions for the exhaust as well as around the dryer. It will need air to burn. (Maybe it's stuck in a corner with clothes or something stacked around it? Maybe it just needs a cleaning like you would your furnace? (i.e. - cob webs)?
Best of luck! :thumbsup:
Clutchcargo 01-02-2009 06:28 PM
63 Attachment(s)
I would take it apart and check the heating unit and fan. You'll be surprised at how little there is inside that box. Most likely you'll have to remove the top and then the front of the dryer to get to the guts.
Winchester 01-02-2009 06:33 PM
Good point about the fan or blower. I too was surprised on how little there actually was "inside that box". :yes: Access to my dryer was exactly as stated, removed the top and then the front. Top may not just lift off but need to slide out of grooves to lift.
