Gas Area Heater Compared To Electric - Appliances - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 09:13 AM   #1
gas area heater compared to electric
i'm planning on adding an area heater.my main source is gas furnace,financially speaking which is better gas/electric?
justorr is offline   Reply With Quote
Old 11-12-2008, 02:24 PM   #2
in my area, gas is cheaper to run. If you have room in your electrical panel, electric will likely be cheaper to install.
Old 11-12-2008, 03:47 PM   #3
Rewards Points: 528
In the northeast, a area gasheater is preferable if it has a vent. The ventless type allows carbon dioxide to enter the room and is not healthy. Note I said CO2 and not CO. But both can give off CO if the heater is prevented from getting sufficient oxygen or not working properly. I have a CO detector in my home in the event the main furnace malfunctions.
I use electric space heaters in my home for safety reasons. I used to have a gas space heater in my basement recreation room and it took me a long time to figure out why I could not easily maintain the pH of the salt water fish tank. The space heater was new but not vented and it would fill the room with carbon dioxide and this in turn would drive down the pH. People can get sick from high levels of CO2. When I first put this ventless spaceheater in service, I did not know of the dangers of high levels of CO2.
rjordan392 is offline   Reply With Quote
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 08:13 AM
over heating electric water heater Jetfuelman Plumbing 6 04-24-2008 09:41 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
