Garbage Disposal Trouble - Appliances - DIY Chatroom Home Improvement Forum
Old 07-27-2014, 09:33 PM   #1
garbage disposal trouble
I have a In Sink Erator in which I don't know how old it is. When I flip the switch just the motor runs that is it. I pressed the reset button but still motor is running and that is it. What could be the issue?
newtda is offline   Reply With Quote
Old 07-27-2014, 09:53 PM   #2
chitownken's Avatar
Rewards Points: 510
Does it run? or just hum?
chitownken is offline   Reply With Quote
Old 07-27-2014, 10:03 PM   #3
It just hums, but I pressed the reset button and flipped the switch it kinda worked for a second.
Old 07-27-2014, 11:40 PM   #4
Rewards Points: 332
Send a message via Yahoo to curtd
A humming electric motor usually indicates that the motor is getting voltage but it isn't turning. The motor chopper blades can be jammed and/or the starting capacitor is faulty. For example, if the starter capacitor fails on a force air furnace the blower motor will hum but will not turn. In my experience, this won't trip the circuit breaker
curtd is offline   Reply With Quote
Old 07-28-2014, 05:44 AM   #5
DIY staff
Rewards Points: 7,174
There is a hole in the bottom,dead center of the unit--insert an Allen wrench into that hole and turn the motor by hand--that should free up the blades--look inside the unit and see if something hard is inside--jamming the blades--remove the junk --
Old 07-28-2014, 01:41 PM   #6
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
and keep in mind what I tell my tenants. Feed it like a baby, small bites and lots of water.
Gregg M.
gmaint is offline   Reply With Quote
Old 10-11-2014, 04:41 PM   #7
Rewards Points: 28
I've just discovered a similar issue with my garbage disposal - it's a Badger 5XP, built in Sep 2006. Here's what I know:
  • It's not jammed - I put a 1/4" allen wrench on the motor shaft and it spins freely
  • Turn on the disposal and the motor hums, but no rotation....after a few seconds of humming, the built-in circuit breaker on the disposal trips, which is what it's supposed to do to prevent the motor windings from overheating
  • Gotta be careful here - after letting the motor cool and resetting the breaker, I turned the disposal on again, and at the same time I tried to turn the flywheel using a wooden pole - the flywheel wouldn't budge at all (tried to tuen counter-clockwise, which is the direction the flywheel would turn normally). It was like the flywheel was frozen in place - very strange, given that when the power is off I can rotate the flywheel manually with no trouble at all.
I'm gonna guess the motor is shot - curious if anyone with a bit of electrical knowledge can explain in any detail what exactly is going on here. What exactly is meant by "the motor is shot, burned out, etc"?
Why won't the flywheel turn with the power on and me trying to help it out with pressure applied in the right direction with the wooden pole? Would think with the power on there would be at least some torque being applied to the flywheel? The flywheel was frozen solid in place with the power on and the motor humming. Again, it turned just fine manually with the power off.
FYI, my disposal has an induction motor, so there's no starter capacitor.
Thx!
Patriot_fan is offline   Reply With Quote
Old 10-11-2014, 05:43 PM   #8
DIY staff
That unit is at the right age for the inner lining to spring a leak--My educated guess? The motor is wet and can't turn on because of it---
Old 10-11-2014, 06:21 PM   #9
Rewards Points: 332
I know something about motors although my following explanation needs tweaking:
Motors contain windings of wire. The wire is all winded tightly together. The insulation on this wire is i believe a varnish. When a motor over heats this varnish can melt off. In a correctly running motor the electrons travel thru these windings in a definite path, but if the windings see too much heat this varnish (insulation) can melt off and now the electrons travel in a less ideal path. Less ideal path = motor may not operate at all. Motors can see to much heat by being overloaded, being in a fire or being close to one (radiant heat)
Old 10-11-2014, 11:03 PM   #10
Rewards Points: 4
IMO and experience we have had this happen to a disposal. We tried the wrench suggestion above but it didn't help. Ended up have to shut down the power to the unit and fish out what was in the disposal. Then ran a cleaner through it with hot water. It worked from then on, but I am not an expert. Good luck!
wyattl is offline   Reply With Quote
Old 10-12-2014, 07:27 AM   #11
Rewards Points: 476
Thx!
most likely the winding in the motor has some how come loose and when you turn on the power on it will be like a magnet and go to the rotor which will stop the armature from turning , my guess
del schisler is offline   Reply With Quote
Old 10-12-2014, 11:27 AM   #12
Rewards Points: 28
Now that makes sense! Appreciate your input.
Garbage Disposal Requirements BigJimmy Plumbing 6 05-01-2014 10:05 PM
Dishwasher and garbage disposal problems longislander2 Appliances 7 01-16-2014 10:11 PM
Having electrical trouble with my garbage disposal Bonavita513 Electrical 11 09-25-2012 07:09 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
