Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-29-2011, 01:16 PM   #1
Garbage Disposal - time to replace?
Seems to be stuck... it only hums
I have used the wrench that came with it & it seems to loosen up the flywheel & then runs for a second or two & starts humming again.
Tried a wooden spoon trick too.. no luck
I leave it on long enough & trips the breaker (either on board or electric panel)
I see no visible debris when I look down into the disposal with a flashlight.
Motor going or is the flywheel just really stuck?
Any suggestions?
Thanks!
deathandgravity is offline   Reply With Quote
Old 01-29-2011, 01:52 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
replace it
hardwareman is offline   Reply With Quote
Best Garbage Disposal ToeJoe Plumbing 1 01-16-2011 10:22 AM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 04:40 PM
Garbage disposal leaks out bottom but only when running sprtfan Plumbing 0 10-07-2010 10:36 AM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Garbage Disposal Drains RickyBobby Plumbing 4 04-28-2010 08:08 AM
