Garbage Disposal Seized Up - Appliances - DIY Chatroom Home Improvement Forum
Old 11-24-2013, 04:04 PM   #1
Rewards Points: 87
I had to replace a 3-year-old disposal this week because the motor apparently seized up. Is there any way to reduce the odds of this happening again so quickly on the new one? The previous disposal lasted at least 10 years.
huesmann is offline   Reply With Quote
Old 11-24-2013, 04:27 PM   #2
chitownken's Avatar
Rewards Points: 510
Are you certain the motor was seized up and it wasn't just something stuck in the grind chamber?
chitownken is offline   Reply With Quote
Old 11-24-2013, 04:36 PM   #3
Rewards Points: 13,300
First thing you do when it locks up is use the Allen wrench it came with to turn it backwards to unstick it.
People seem to think they can grind up anything to make it go away.
I've seen anything from chicken bones, lobster and clam shells, to spare ribs stuck in them.
Just my own opinion but a garbage disposal is about the most useless invention since the electric can opener. The only one that loves them is plumbers.
Since your in DC you may not have a garden but the scraps make great compost.
Old 11-24-2013, 04:42 PM   #4
chitownken's Avatar
Rewards Points: 510
My daughter's disposal was locked up. Gravel from the aquarium. Not a clue why they tried to run it through the disposal.
Old 11-24-2013, 05:20 PM   #5
Rewards Points: 87
I'm sure nothing was stuck in the grind chamber.
All I toss down there is small/soft food scraps. Actually, I even use a strainer on the sink drain and stuff that gets collected in it gets tossed in the garbage can. Large/hard stuff gets tossed in the garbage or the compost heap out back.
Old 11-24-2013, 05:26 PM   #6
chitownken's Avatar
Rewards Points: 510
OK. So if the motor seized up after 3 years I would buy a different brand of disposal, or at least a different model. Not much you can do to prevent motor seize up other than be careful what you feed to the disposal. Make sure you don't run it "dry" as that can damage the shaft seal which could lead to water getting to the upper motor bearing leading to bearing failure.
Old 11-24-2013, 05:29 PM   #7
Rewards Points: 87
Yeah, I got a different brand this time. Wish I could remember what the one was before that lasted 10 years! Maybe Insinkerator?
Having electrical trouble with my garbage disposal Bonavita513 Electrical 11 09-25-2012 08:09 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Double dishwasher, dble sink garbage disposal dilemma pettychat Plumbing 2 01-12-2012 04:43 PM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
