-   -   Garbage Disposal Just Not Getting it Done (http://www.diychatroom.com/f47/garbage-disposal-just-not-getting-done-125326/)
RCrosby257 12-02-2011 11:15 AM
I've come to really appreciate the prompt responses and willing sharing of expertise I've found here at DIY.
Here's the latest. Have a Badger 5, 1/2 h.p. under the sink garbage disposal. Seems to work fine; I run the water, turn it on, and it makes all the right sounds and moves stuff around, but it just doesn't seem to really chop things up or get rid of it. I've done enough online research to know that I'm not putting the wrong things down there and since the water runs right through I don't think it's clogged. Put in some lemon peels this morning. Cut them into about 2" chunks before sending them down the hole. Ran the water and turned it on for about a minute. They're still there.
Dull blades? What? I'm comfortable disconnecting it and having a look see but really don't know what I'd be looking for, or if it's a job I shouldn't even attempt. Any suggestions greatly appreciated. :) Rob
hardwareman 12-02-2011 06:26 PM
maybe something is stuck under one of the choppers and not letting it rotate. Take a flashlight and look down into it, locate the 2 blades now take a long handled wooden spoon and see if you can move the blades around
RCrosby257 12-02-2011 09:09 PM
Garbage Disposal Not Working
Hardwareman,
You hit that nail right on the head!
One of the blades was stuck.
Works like a champ now!
Thanks!
Rob :thumbup:
RCrosby257 12-06-2011 08:03 PM
Garbage Disposal Just Not Getting It Done
Well, it was great while it lasted, which wasn't long. My fault, I suspect.
It was working so well, I fed it a whole bunch of lemon peels. It started grinding away, and then just quit. No sound, no "nuthin". I turned off the switch thinking it might have overheated and thrown a unit or household breaker. All household breakers are fine as is the ground fault switch on the plate that has 2 plug outlets along with the motor switch. I was hoping to find a "reset" button on the motor, but if it has one, I haven't found it yet.
It's a Badger 5, In-sink-erator, 1/2 h.p. Did I kill the motor? Or is there a reset button hiding on me? Some else?
Thanks, AGAIN! :whistling2:
DannyT 12-06-2011 10:24 PM
there is a small red reset button on the bottom of the disposal. its hard to find just feeling around. get a mirror and a flashlight and you should be able to find it.if it starts going again throw a few trays of ice cubes in it. they will not off any gunk that is stuck in the teeth along the sides. if it ever gets jambed there is a hex socket in the center that an allen wrench will fit into to get it unjammed. make sure the switch isn't on if you need to unjam it.
hardwareman 12-06-2011 11:44 PM
has a very small reset button underneath
RCrosby257 12-07-2011 01:16 AM
Garbage Disposal
You folks are the best! Thanks AGAIN! :thumbsup:
