Garbage Disposal Help - Appliances - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 08:58 PM   #1
Garbage disposal help
Just got home from a long deployment, apparently my kid got some fish tank gravel in the disposal, it won't work now an has not for months, how can I clean this mess out?
ffhall54 is offline   Reply With Quote
Old 09-05-2013, 09:08 PM   #2
Rewards Points: 5,974
Have you tried to use the little wrench that came with it or a screw driver to manually turn it in reverse to see if that will free it up. And thank you for your service.
Old 09-05-2013, 09:10 PM   #3
Your welcome, and yes I tried..... No such luck, the gravel is small and my hands are pretty big
Old 09-05-2013, 09:13 PM   #4
Probably the next best thing would be to remove it (not really a big job) and turn it upside down. But you will probably end up replacing it. Maybe someone else will come along with a better idea.
The Following User Says Thank You to ToolSeeker For This Useful Post:
plummen (09-06-2013)
Old 09-05-2013, 09:17 PM   #5
That's what I was thinking, didn't know if there were any tips or tricks before I went to replace it
Old 09-05-2013, 09:37 PM   #6
You don't have to completely remove it just loosen the ring drop it down, turn it upside down try to knock every thing loose. After you get as much gravel as you can out then try reversing it by hand again. Up on further thought when you tried to turn it with the tool did it turn? When you turn it on does it do anything like hum? Have you tried the red reset button on the bottom? Have you checked the breakers in the box?
Old 09-05-2013, 09:58 PM   #7
It will hum then trip the red button on the bottom, no breaker or GFI issues, the tool would not let it spin at all
Old 09-05-2013, 10:41 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 664
You'll have to take it off the sink and attempt to clear the obstruction.
Sounds like gravel is binding the unit
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
plummen (09-06-2013), ToolSeeker (09-06-2013)
Old 09-20-2013, 06:38 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
I used a 4' wrecking bar to free up seized units that had not been used for years. If you cant break it loose with that much leverage then plan on replacing it.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
oh'mike (09-20-2013)
Having electrical trouble with my garbage disposal Bonavita513 Electrical 11 09-25-2012 07:09 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 05:19 PM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 02:02 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 03:00 PM
