Garbage Disposal - Appliances - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 04:56 PM   #1
garbage disposal
Can I wire a garbage desposal to work without using an electrical wall switch
rcm1945@aol.com is offline   Reply With Quote
Old 07-04-2011, 05:35 PM   #2
the Musigician
DangerMouse's Avatar
Sure! But your utility bill will surely rise from running a garbage disposal motor 24/7....
How do you plan on turning it off with no switch?
DM
Old 07-04-2011, 05:40 PM   #3
Journeyman Wireman
Rewards Points: 150
You could wire the switch inside the lower sink cabinet. That way it won't be visible. Or you could use a disposal air switch.
http://www.insinkerator.com/pdf/ISE-...opswitch_r.pdf
Jupe Blue is offline   Reply With Quote
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 04:40 PM
Object in Garbage Disposal coolptnr Plumbing 3 05-18-2010 03:02 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 11:03 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
