Garage Door Opening And Closing At Random - Appliances - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 12:49 AM   #1
Garage Door opening and closing at random
Its a craftsman 1/2. From the looks of it (came with the house) its about 4-5 years old.
First the programmed key in my car to open and close the door stopped working. After it finally opened, I hit the learn button to reprogram the car and it shut the door. So I went back to the wired keypad and opened it.
It shut it immediately when it got to the top. This went on for a while until I gave up because I had to leave. All the while, this green light which I'm assuming is for the learned remote was flashing wildly.
I came back tonight and even though I had set it on manual, it had apparently tried to open and close again because it had reengaged the motor and tried to pull the door up again. (I had the door locked because I had left it on manual open)
Tonight, I tried the actual remote and it worked on and off but was still opening and closing at random.
Finally I shut it and unplugged the unit.
Anyone ever heard of this before? I haven't touched a thing on it ever.
texmaster is offline   Reply With Quote
Old 08-22-2010, 08:44 AM   #2
Rewards Points: 6,652
Do you have the safety eyes at the edge of the garage door, to sense for objects in the path of the door?
Old 08-22-2010, 09:13 AM   #3
Yes and I checked them but would they also force the door to shut automatically?
Old 08-22-2010, 11:18 AM   #4
firehawkmph's Avatar
Rewards Points: 1,800
Tex,
Short of an exorcism, here's a few things to try.
Disconnect the wired keypad just to get it out of the system for now. Everything nowadays is wireless, which basicly just adds another remote to the system.
Next, go to the opener head, push the learn code button and hold it down until the green light next to it goes out. You have now cleared all the codes out of the memory.
Disconnect the door from the opener by pulling the cord and run the door up and down by hand to assure it rolls smoothly and without requiring undue force from you.
Hook the door back up and try using the wall button to run the door up and down. If it works that way, next, get your remotes and hit the learn code button and code up each one. Check the operation with the remotes.
One thing, with the sears operators, don't run the door up and down more than 7 or 8 times in a row without giving it a break. It's pretty easy to burn up the starting capicitors on these. If you see a big puff of smoke come out, the capicitor is history.
The other thing you may want to do is turn up the opening and closing force adjustments on the opener head before checking the operation. If everything gets to working properly, then you can back them off to their proper adjustment. Let us know what happens.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-22-2010, 11:20 AM   #5
Anyone in the area have a new garage door/opener installed ?
Old 08-22-2010, 12:33 PM   #6
Registered User
Rewards Points: 4,924
"I came back tonight and even though I had set it on manual, it had apparently tried to open and close again because it had reengaged the motor and tried to pull the door up again. (I had the door locked because I had left it on manual open)" -------
This is a problem with the opener, not an outside influence. Did you look on the web at the manufacturer's F&Q's? The flashing lights are the clue:
http://www.geniedoor.com/troubleshooting-guides
http://www.wayne-dalton.com/resident...r-openers.html
http://help.chamberlain.com/help/en-us/faq
Be safe, Gary
Old 08-25-2010, 08:08 AM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I agree that the lights are probably a clue, but disagree that you can rule out an outside influence. Depending on the exact door, many will still turn on if in manual mode ( since on many doors manual is simply a disconnect from the drive mechanism) So if the door is in "manual" and you hit the button, motor still functions, just doesn't lift or lower the door. It could be that the button in the car is malfuntioning ( sticking) and constantly sending a signal to the door. The flashing lights could simply be an indicator that the open is recieving a signal. Park the car out of range, see if anything changes then. it could also be that when you were reprogramming car remote, you didn't finish the process...
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Garage door problem - not closing completely francis Electrical 4 07-08-2010 01:27 AM
Garage Door Questions: closing sides and safety reversal jage Building & Construction 10 11-10-2009 08:57 AM
Auto Garage door not always closing fully whatsthis Building & Construction 13 04-22-2009 01:42 PM
Closing In Garage Door Opening all vinyl Building & Construction 2 10-30-2008 06:21 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 03:09 PM
