Garage Door Opener Question - Appliances - DIY Chatroom Home Improvement Forum
Old 05-02-2013, 09:10 PM   #1
Rewards Points: 89
Garage Door opener question
Apologies if this is best suited for another category....
Ran in to some issues with the garage door opener at one of my properties yesterday. It's an old Craftsman opener (mid-80's?), don't have the model number at the moment.
When I initially was checking remotes before new tenants moved in, neither worked. The door itself opens just fine with the wall-mounted control. Played around with them more, put in new batteries, etc. Found out that the remotes do work, but they have to be really close to the receiver. Within 3 feet they work somewhat regularly, work even better within a few inches. Jumpers are still set in the proper positions, LED indicators on the remotes light up strong and bright.
Any ideas what might be causing this?
dvaupel is offline   Reply With Quote
Old 05-03-2013, 09:47 AM   #2
Rewards Points: 1,300
some model door openers have an antena wire hanging from the opener unit itself. If that was removed or damaged it can affect the operation.
danpik is offline   Reply With Quote
Old 05-03-2013, 09:49 AM   #3
Rewards Points: 89
This model has a separate receiver box that is plugged in the ceiling-mounted receptacle right next to the opener. It's still working and picking up signal from the remote, just not from more than 6 feet away
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 12:30 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
