Garage Door Opener Help - Appliances - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 11:40 AM   #1
Garage door opener help
Hello this is my first post. Sorry if I am not in the right place. I am trying to fix my garage door opener. I did a replacement of the main sprocket gear and now when I push the button it only opens a out a foot then it immediately closes. What can I do pleas help
Radrich is offline   Reply With Quote
Old 03-02-2013, 11:51 AM   #2
Rewards Points: 13,750
Pull on the rope to reliece the opener in the closed position.
Now by hand open and close the door.
Should be easy to open with one hand and should be able to stop in any position and have stay.
Old 03-02-2013, 01:04 PM   #3
Remodeler
Rewards Points: 326
This is the chamberlain/liftmaster style opener?
Check the RPM sensor, the black segmented wheel on the end of the worm drive shaft. Make sure it is pushed all the way on the shaft so that the segmented rim actually splits the pickups of the sensor board. Also make sure the wires are plugged into the sensor board correctly, not disconnected or off by one pin.
This is the best pic I could find
http://www.amazon.com/gp/customer-me...e=UTF8&index=1
iamrfixit is offline   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 10:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
