G.E. Refrigerator Icemaker Does Not Work - Appliances - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 06:55 PM   #1
Post
I have a G.E. Refrigerator, Model#GSS22WGPC and the Ice Maker recently stopped working. There is no ice in the tray and no water in the tray. As far as I know, it does not have a Eye Beam or wire handle. Per the manual, it has a feeler arm that when ice is produce and reaches to the level of the feeler arm, it stops producing ice. The manual is located at this site http://products.geappliances.com/Mar...e=49-60458.PDF. I know it isn't the water line because I get water from the dispenser. I've followed the troubleshooting advice from the manual and still nothing. Can anyone tell me what could be wrong?
g8tkeeper is offline   Reply With Quote
Old 01-21-2010, 05:34 PM   #2
Rewards Points: 530
Which dispenser? Water in the door or the tube going to the icemaker?
Old 01-21-2010, 09:17 PM   #3
Water in the door
Old 01-22-2010, 03:01 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 514
Bad valve in back and under the fridge
Old 01-22-2010, 08:33 PM   #5
Rewards Points: 530
Thats what I was getting at. Double inlet valve supplying water with a bad solonoid on one side
Old 01-23-2010, 05:42 PM   #6
Rewards Points: 6,652
Here is a list of the parts at repairclinic.com http://www.repairclinic.com/Applianc...S22WGPC-%3d%3d The valve is $49.05. I ordered a part for my wash machine on Tuesday night, and got it via Fedex Friday morning. I have used the above mentioned site and have been happy getting stuff quickly and no questions if needing to be returned.
Old 03-19-2010, 08:41 AM   #7
It's been several month since I started this thread and I haven't fix this problem. You guys stated I needed to replace the dual water inlet valve because the assumption was that water was not being supplied to the icemaker. So that I won't waste money or time and to be sure, is it possible that the ice maker is not working properly?
Old 03-19-2010, 08:51 PM   #8
I had the same problem. changed the ice maker, it still didn't work. Turns out it was a bad fan in the freezer. check the temp in the freezer, It should be near Zero. If it's too warm the ice maker will not work. The only things that can break are the freezer fan, the water valve and the main circuit board. If it's the fan most likely the main board is bad too. The circuit board is $100. The water valve is about $40 a new ice maker is $150.
check out this site...http://www.appliancepartspros.com/index.aspx
UFoPilot is offline   Reply With Quote
Old 07-01-2010, 07:27 AM   #9
Maybe similar problem going on with mine...no real troubleshooting yet as I just saw this last night...freezer was at 3 degrees instead of 0 and there was water trickling into I guess the icecube maker - it looked as thought the cubes were melting, but yet the rest of the freezer goods feel frozen (0 vs 3 should not melt stuff - right?) Is it possible for the water to not be shutting off or something after it has filled the tray? It is only 3 years old. Again I have not done my troubleshooting yet. This morning the freezer was back down to 0, but I have not turned icemaker back on.
Any thoughts? Is there a control valve or sensor that tells the water to stop flowing into the ice tray? Water dispenser works fine.
Anyway - firgured I would throw these questions out there as I dig a little deeper. Thanks for any replies. The sooner I can make the wife stop yelling about it the better
tbone2004 is offline   Reply With Quote
Old 07-01-2010, 04:32 PM   #10
Rewards Points: 530
Water trickling in from the inlet tube?
I would not be concerned about the 3 degrees fluctuation. Maybe it had just dumped ice or just getting ready to. Some of the older icemakers had heaters in them that would heat the ice enough to make it easier to rake out of the tray.
The ice maker tells the inlet valve how long to run. 5 to 8 sec's or something like that, maybe a little longer depending on model.
If the tube starts freezing up, you might want to check the valve as it may not be shutting completely off. This can cause it to freeze up. Kind like an ice dam. Little by little little pieces of ice began to form until it causes a blockage.
Old 07-07-2010, 09:16 PM   #11
The dual water inlet valve was replaced and still no ice. The freezer fan is working and the temperature setting is at "9" for coldest and the items in freezer are frozen. I assume it is at least 0 degrees fahrenheit. Before I shell out $170, is it possible that it isn't the icemaker but the main circuit board or something else? Please advise
Old 07-09-2010, 06:04 PM   #12
Is there a way to check if it is the main circuit board versus the ice maker?
Old 07-09-2010, 09:02 PM   #13
Rewards Points: 530
If I remember correctly, back when I fooled with appliances, the icemakers did have a connection you could cross out too see if it would send the signal to the inlet valve. Since the circuits boards came out, I am somewhat lost on these things.
If the inlet valve is still like the older ones, they can be checked before replacing with or without live power. I guess we should have mentioned that, sorry.
I have no experience with the circuit boards, but I have read of problems with some of them.
It used to be you could sort of count on finding a problem in the df system, timer, stats, etc. I don't know if the newer one even have timers in them now that the circuit boards are used.
The temps seem okay. 10 degrees is a good temp to freeze most things. If you like your ice cream hard, you may want to go a little colder.
I suggest you google 'appliance repair'. I bet you find a place that will almost walk you through the trouble shooting for this fridge.
Wish I could be of more help, but I don't want to feel I cost you money by giving advise on an appliance I am not familiar with.
Old 07-10-2010, 06:22 AM   #14
i know this is a DIY forum but that refrig is a little complicated. instead of wasting money by throwing parts at it, have it serviced by a local guy who knows the GE artica style refrigs[ask]. the problem with those 'help' sites-IMO- is; they really want to sell you parts. and on the ones where they take all the 'rent a parts' back-what happens to those parts?
Jacques is offline   Reply With Quote
Tags
icemaker , refrigerator
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 07:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Properly Sealing HVAC Duct Work craymer45 HVAC 5 11-06-2008 08:47 PM
