Furnace Trouble - Appliances - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 01:14 PM   #1
Furnace trouble
We have an HEIL DC90 Ultra High Efficiency furnace. It randomly starts blowing out cool air instead of warm air. We live where it snows so this is a big problem. We have tried turning it off and unplugging. Sometimes it works and sometimes it doesn't. It will be working fine and then all of the sudden blowing out cold air. Do you know what could be wrong and what we could try to fix ourselves before paying a professional?
Scrapbooker is offline   Reply With Quote
Old 01-15-2011, 09:19 AM   #2
Rewards Points: 494
Try cleaning sensor by one of the burners with emery cloth, fine steel wool or sandpaper.
If no success, start a new post in HVAC section.
Tell what point you are at:
1. Combustion fan on
2. Pressure hose jumps, air pressure switch closes
3. Ignitor glows
4. Gas valve opens, burners light
5. Blower motor starts
diyorpay is offline   Reply With Quote
Old 02-08-2011, 12:42 AM   #3
Lately while cleaning the basement, the drain hose located on the right side of the furnace was lifted about furnace height. This kept the furnace running and putting out little heat. When I lowered the hose back to the floor a small amount of water ran out. When the hose was drained the furnace works like it's supposed to. This makes me believe a lot of problems arise from the hose being plugged up, water does not run uphill and clogged the hose. I believe this may cause the furnace to malfunction. Hope this helps
Jerry S is offline   Reply With Quote
furnace trouble jkwilson HVAC 17 11-01-2009 10:23 AM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
