Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-27-2012, 03:02 PM   #1
furnace trane xe80
furnace does not start. I try blow fan does not start also, what is the problem
larion is offline   Reply With Quote
Old 09-27-2012, 09:12 PM   #2
silver_flash's Avatar
furnace trane xe80
is there batteries in the thermostat ? if there is, was everything in the off position when the thermostat was pulled off the wall? is there a pilot light?
silver_flash is offline   Reply With Quote
Old 09-28-2012, 02:11 PM   #3
furnace trane xe80
did you check the circuit breaker to see if it has power?
allthumbsdiy is offline   Reply With Quote
Trane XE80 furnace, best filter to buy dinosaur1 HVAC 33 02-11-2012 12:59 PM
Trane furnace problem - can't figure out! fedupfurnace HVAC 7 10-22-2011 03:21 PM
Trane xv80 install draft exhaust wires on furnace biggiant HVAC 5 02-10-2009 07:50 PM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 06:53 AM
Help TRANE XE-80 furnace squeed HVAC 12 10-08-2006 09:22 PM
