Furnace Fan - Appliances - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 06:25 PM   #1
furnace fan
how much does it cost to run my furnace fan in the summer
bobbo123 is offline   Reply With Quote
Old 08-13-2011, 06:42 PM   #2
Experienced
Jackofall1's Avatar
Welcome bobbo123, to the best darn DIY'r site on the web.
Cost the same in the summer as it does in the winter.
Continuous running fan up to $40/mth depending on your cost per Kwh.
Mark
Old 08-13-2011, 07:21 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Figure how many watts it takes (you can use a clamp on meter at the panel, check voltage then multiply by that voltage). then times that by your price per w/h times 24 times 30. Note that this is only an estimate unless you have an expensive true RMS meter that will give you the proper amp reading. Cheaper ones can be off by quite a bit.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
