Furnace - Appliances - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 08:15 PM   #1
furnace
what would it cost to replace a motor #1011409fa in my heil furnace
Ron Kelley is offline   Reply With Quote
Old 04-17-2013, 08:28 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
you talking hiring an hvac company or buying the motor and doing it yourself? you need the motor specs, on the motor itself; hp, volts, amps, speeds (three or four speed?). and it has to be the same motor, not one for an outside condenser.
try Grainger if you have one near you. buying it yourself would be cheapest, under $100.00.
Thanks.
Doc Holliday is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
