Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-12-2011, 09:47 AM   #1
Household Handyman
Funky washing machine
O.K., so I have an eleven (11) year old Kenmore (Maytag ?) washing machine that has been very good for a lot of years, But--withing the last year there has been an unusual problem with it. This machine will just stop working, anywhere it desires within the cycle. I can hear the timer clicking, the water comes in fine, but nothing else will work. Then I discover that if I tilt the machine back enough to get my hand under it, then find the motor/tranny coupling and rotate this by hand a few turns: All will work again. I've been in industrial maintenance for 38 years and never seen an electric motor with what may be a "dead spot" but this is what this motor is acting like. So to the motor people: Could that be a "dead spot" in the motor winding that would cause this? Thanks
Old 11-12-2011, 11:03 AM   #2
STAFF
BigJim's Avatar
You may have a loose belt, that was one problem I had also and that took care of it. We goofed up and bought one of the new fangled washers with the low profile agitators, that sucker will tear your clothes up, I wish we had the old washer back.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 11-12-2011, 11:36 AM   #3
Household Handyman
Thanks, but no belts on this model. Motor is coupled to the transmission. Coupling has a rubber insert that is replaceable, this has been inspected and is in good shape. Sometimes this happens soon, other times it may go another year. I think I'll give it a female name
Old 11-12-2011, 05:51 PM   #4
Yes it is possible for a motor to have a dead spot where manually rotating it a fraction of a turn (with the power off please) will cause it to start normally the next time. Yes, for AC motors this is usually due to a bad winding.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 11-12-2011, 06:33 PM   #5
Is there a starting and/or run capacitor on the motor?
Master of Cold is offline   Reply With Quote
Old 11-12-2011, 07:18 PM   #6
STAFF
BigJim's Avatar
Sorry bout that, our washer must have been a lot older.
Jim
Old 11-13-2011, 11:58 AM   #7
Household Handyman
@ "Master": At this time I do not know it there are either a run or start cap on this motor, please understand that I have no desire to turn this machine on it's back if I can keep it running. This peculiar problem only surfaces maybe twice a year. Thanks for asking though. @ "Allan J", YES, I do pull the cord before putting my hand under there. I also place a piece of 4x4 under the machine to assure it stays up just enough to reach under it. Thanks
Old 11-14-2011, 07:19 AM   #8
If it had a 'dead spot' you'd still hear a hum. i suspect you have a bad wire maybe at the motor plug [white-common]. by tilting and jiggling, it reconnects? if this is a direct drive=no belt] that whole wrap around comes off for better diag'.
Jacques is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
