Frozen Ice Maker Fill Tube - Appliances - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 02:23 PM   #1
Rewards Points: 37
frozen ice maker fill tube
Hello,
My ice maker fill tube is filling with ice!!! The ice mold is full and the ice chunk continues to the tube. I have had to remove the unit to thaw it out. It worked fine overnight but then froze again. What could be causing this?
I recently had a pinhole leak in the fill tube supply and used a quick connect adapter to repair it. Could this be the problem?
Thanks.
nbmech is offline   Reply With Quote
Old 02-06-2013, 03:44 PM   #2
Rewards Points: 13,250
Model, make?
Old 02-06-2013, 04:00 PM   #3
Rewards Points: 37
Kenmore fridge
ice maker 106.626636
Old 02-07-2013, 12:03 AM   #4
the problem is the pin hole in It you should call the company of which you are using the appliance and ask them to send the maintenance officer to your place to check the ice maker.
paulsmith544 is offline   Reply With Quote
Old 02-07-2013, 06:36 AM   #5
Rewards Points: 1,294
I would suspect that the end of the tube is now in the water tray. It should not be.
danpik is offline   Reply With Quote
Old 02-07-2013, 07:28 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
sounds like your fill valve is seeping. You'll have to replace the valve
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 10:28 AM
Jacking up shed nikeman Building & Construction 16 03-26-2012 09:35 PM
Knob & Tube -- Cellulose Insulation rlowe82 Electrical 23 11-08-2011 01:03 PM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 10:27 AM
HELP - No Water to Ice Maker noice Appliances 13 07-17-2007 10:41 AM
