Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-25-2012, 01:47 PM   #1
Frost on shelf of Kenmore bottom freezer
How can I prevent frost from accumulating on items on the shelf next to the ice maker in my Kenmore refrigerator/freezer? This is the only place frost is a problem. The basket portion of the freezer and the refrigerator seem to be working fine.
Sally1965 is offline   Reply With Quote
Old 06-25-2012, 03:37 PM   #2
No can do. EVERY fridge will have a colder spot....
Just know where it is....and put stuff that may possibly *freeze* and you are okay with over there.....
And yes, I'm clear you are talking about the fridge side of the fridge and not the freezer
mobiledynamics is offline   Reply With Quote
Old 06-25-2012, 10:12 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
there is absolutely no reason to have frost build up in your freezer, anywhere. I would suspect you have an air leak some where. Check your door gasket to make sure it is sealing good all the way around
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Sally1965 (06-27-2012)
Old 06-26-2012, 06:31 AM   #4
Some other things might be; if i/m not hooked up and not set to off. if refrig is an LG-795 prefix [no model/serial #-so don't know what you have] there's some bulletins for this condition. if so you'd have to contact Sears as LG won't give any info on Kenmore's.
Jacques is offline   Reply With Quote
The Following User Says Thank You to Jacques For This Useful Post:
Kenmore fridge not cooling but freezer is working perfectly. l.shemon Appliances 13 11-26-2011 04:50 PM
Door bottom (sweep) operagost General Discussion 6 12-06-2010 11:26 AM
Ice building up in the bottom of the freezer in layers lyleogle Appliances 8 11-13-2010 12:27 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 08:59 AM
Freezer odors - coming from blower/fan Richo Appliances 3 05-27-2009 06:26 PM
