-   -   Frost on shelf of Kenmore bottom freezer (http://www.diychatroom.com/f47/frost-shelf-kenmore-bottom-freezer-148215/)
Sally1965 06-25-2012 01:47 PM
How can I prevent frost from accumulating on items on the shelf next to the ice maker in my Kenmore refrigerator/freezer? This is the only place frost is a problem. The basket portion of the freezer and the refrigerator seem to be working fine.
mobiledynamics 06-25-2012 03:37 PM
No can do. EVERY fridge will have a colder spot....
Just know where it is....and put stuff that may possibly *freeze* and you are okay with over there.....
And yes, I'm clear you are talking about the fridge side of the fridge and not the freezer
hardwareman 06-25-2012 10:12 PM
there is absolutely no reason to have frost build up in your freezer, anywhere. I would suspect you have an air leak some where. Check your door gasket to make sure it is sealing good all the way around
Jacques 06-26-2012 06:31 AM
Some other things might be; if i/m not hooked up and not set to off. if refrig is an LG-795 prefix [no model/serial #-so don't know what you have] there's some bulletins for this condition. if so you'd have to contact Sears as LG won't give any info on Kenmore's.
