#1 |
Frost in freezer-Whirlpool
I have a Whirlpool refrigerator, Model EST 15PM. I have frost in the freezer section. I have read to check the drain holes and the defrost timer.
1. What do I remove to check the drain holes? 2. Where is the defrost timer located? How do I access it? 3. This is an older unit (about 40 years old). Is a defrost timer still available and at what cost? Also, the blower motor in the freezer dept. does not turn off. Is that a clue to my problem? Thanks, Jerry 10/4/12 Last edited by Jerry8C; 10-04-2012 at 12:49 AM. Reason: More information |
#2 |
#1 HAWKEYE FAN
frost on the evaporator coil would indicate a defrost problem. Defrost system has 3 parts, timer, heater, and thermostat. Could not locate your model but usually whirlpool defrost timers were in the back of the refrig unit by the controls. If oem part is not available there should be a generic to cross over to.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"........... |
| The Following User Says Thank You to hardwareman For This Useful Post: | Jerry8C (10-04-2012) |
#3 |
JOATMON
40 years? Unless your saving the unit because it's a classic.....time for a new one.....
A new fridge will use just a fraction of the energy this one does. I would not spend a cent on it....unless it has some other value...such as keeping beer cold in the man cave.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Frost on shelf of Kenmore bottom freezer | Sally1965 | Appliances | 3 | 06-26-2012 06:31 AM |
| Whirlpool Refrigerator Dripping from freezer into fridge. | JH6 | Appliances | 2 | 02-04-2012 02:25 PM |
| Ice and frost inside frostless freezer | dannat | Appliances | 4 | 06-21-2011 06:50 AM |
| Help My Admiral Refrigerator is leaking water | Cuwillis | Appliances | 9 | 03-22-2011 09:40 PM |
| Kenmore fridge stops cooling with frost in freezer | donnoit | Appliances | 3 | 09-20-2010 08:59 AM |
