Front Loading Washing Machlne - How To Clean - Appliances - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 07:40 PM   #1
Front loading washing machlne - how to clean
What is the easiest way to clean the dispenser drawer and the inside of that section? We have a newer Samsung washing machine.
dinosaur1 is offline   Reply With Quote
Old 02-06-2012, 08:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
by dispenser drawer doyou mean the softner, soap and bleach dispenser? If so, pull the dispenser open as far as you can, Look right in the middle all the way to the back of the dispenser. You should see a release tab there. Press down on it and pull the dispenser all the way out.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-06-2012, 08:44 PM   #3
Yes I know how to remove it, but how can I thoroughly clean the dispenser and the area it slides into?
Old 02-07-2012, 07:53 AM   #4
#1 HAWKEYE FAN
Either I'm missing something or I'm just a little dense this morning. If you know how to remove it, I would think the rest would be fairly obvious. Soak the dispenser in hot water or even throw it into the dishwasher to clean.
Old 02-07-2012, 08:11 AM   #5
Thanks, but what about the area that the holds this dispenser.
Old 02-08-2012, 06:01 AM   #6
should be self cleaning as the house water runs through it. unless it's gunked up from undiluted fabric softer.. if it's a water prob=iron/lime/etc. could try putting LemiShine* in dispenser and running clean cycle.
Jacques is offline   Reply With Quote
Old 02-08-2012, 10:29 PM   #7
We use downy fabric softener. Dispenser drawer and the area it slides out of eems gunked up a bit in some places.
Old 02-09-2012, 07:17 AM   #8
you have to dilute it, be careful not overfill as you add water.
Old 02-09-2012, 07:32 AM   #9
Our manual doesn't say this
Old 02-09-2012, 08:21 PM   #10
How do I clean the dispenser and the area the dispenser sits in to get the gunky black stuff out?
Old 02-09-2012, 08:50 PM   #11
bbo
is that mold?
we leave our drawer and door open when not in use ... I'd probably just clean that with diluted bleach
bbo is offline   Reply With Quote
Old 02-09-2012, 08:53 PM   #12
Originally Posted by bbo
is that mold?
I'm sure all washing machines have black mushy spots like I have that are hard to get to. The issue is how to reach them to clean it.
Mold? I doubt it. I clean this weekly.
Old 02-11-2012, 02:39 PM   #13
bbo
you could try an old toothbrush to get in the nooks and crannies. diluted bleach should help to clean it.
I can't answer on the fabric softner since we don't use that, but diluted does sound right to me. easier for the nmachine to wash it all in to the load.
Old 02-11-2012, 02:43 PM   #14
Bleach on the toothbrush? And then wipe down with rag & warm water?
Old 02-11-2012, 02:52 PM   #15
bbo
sure, just get a little capfull to dab the toothbrush in.
the part you remove from the washer you can just rinse off.
you can wipe off the inside part of the washer when you are done.
if you want to go the pricey but easy route, they make HE washer cleaner tabs. I think tide, whirlpool and weveral others. I've never used this.ymmv
I think one of the most important things when washing is to make sure you are not overdoing the detergent. I remember a good rule of thumb is that if you see suds, you are using too much. use a little less next time.
We actually cheat here and use regular powder detergent. When we got ours a couple years ago, the tech who brought it recommended using 1/8 cup of regular detergent. Seems to work great for us.we have no problems with clumping, smells or gunk. When you use too much detergent it tends to stick in the washer and not rinse out fully.
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 08:23 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 01:57 PM
Front Loader Fridgidair Washing machine Banging Noise when Spinning dads gt Appliances 1 04-05-2009 09:22 PM
Kenmore front loading washing machine rtyui2 Appliances 1 01-04-2009 11:46 PM
LG Front loader washing machine repair sharz Appliances 1 04-19-2008 10:30 PM
