Front Load Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 12-04-2007, 11:27 PM   #1
Rewards Points: 1,088
Front Load Washer
Many companies have pedestals that can be purchased with their front loading washers. Question is how does this affect the typical emergency drain pan that is usually installed under the washer. How is this done? Can you even open the pedestal drawer without hitting the pan's lip? I know the pedestal is not necessary, but these washers look better with the pedestal.
handy man88 is offline   Reply With Quote
Old 12-04-2007, 11:32 PM   #2
ICF Construction
The legs are adjustable up to 1 1/2", that should clear the pan
Chris
Chris Johnson is offline   Reply With Quote
Old 07-01-2008, 09:55 AM   #3
use vibration isolation pads and kill two birds with one stone
I have experieced the same problem. I added a pedestal to my frigidaire washer that I already had in a pan. I noticed that the higher a raised the pedestal with its legs the more the washer shook and vibrated. It made the washer more noisy as well. (the drawer would shake open on its own) I used some ShakeAway pads and lowered the legs on my pedestal. The pads are about an inch thick and raised the drawer up enough to clear the drip pan. My washer is much quieter an doesn't jump around as much. I've noticed that it still vibrates because it is higher but it doesnt shake the house!
homeownertm is offline   Reply With Quote
Old 07-01-2008, 11:16 AM   #4
Crabby Bastard
terri_and_jj's Avatar
Had the same experience. As-is, the drawer won't clear the drip pan, (on most models). You can crank the screws up high, but this makes the washer less stable when it hits those super high RPMs during the spin cycle.
terri_and_jj is offline   Reply With Quote
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Kenmore Top Load Washer gone Crazy ! kourso Appliances 1 07-09-2007 12:48 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
