Frigidare Oven Not Keeping Accurate Temp - Appliances - DIY Chatroom Home Improvement Forum
Old 12-20-2011, 09:15 PM   #1
Fire Alarm Tech
Alleytom's Avatar
Question
Frigidare oven not keeping accurate temp
Hi, I have an issue with an eight year old Frigidaire stove, the oven doesn't keep accurate temperature. I tested the temp sensor and it metered right (1100 ohms between terminals) and metered both elements (oven & broiler) and both were about 40 ohms. We went out and bought an oven thermometer and found that when set to 425 the oven will go to almost 500, then down to 350. When set to 325 it goes to 355. Any suggestions before I spend $140.00 on a new control board?
Alleytom is offline   Reply With Quote
Old 12-20-2011, 10:34 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
nope, sounds like a new board is in the works. Although to make sure your sensor is not really the problem you should ohm it at different temps.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Whirlpool Range Oven Temp Swing horrocks Appliances 24 12-05-2011 11:32 AM
Wall oven temp off by 40-50 degrees MovedTooMuch Appliances 4 12-02-2011 10:37 PM
New Kenmore Range 790.92604 wide fluctuation in oven temp tkolarik Appliances 5 09-10-2011 08:17 AM
problems with keeping house at normal temp hollylzahn HVAC 5 07-21-2011 03:32 PM
