I have a side-by-side Frigidaire refrigerator, model FRS26ZNH. Most of the time when you push the actuator it takes a 10-20 seconds for the light to come on and dispense water or ice. When this problem occurs sometimes the filter light will come on and sometimes it won't. If the filter light doesn't come on then you have to release the actuator and push it again. If the filter light comes on then you can hold it for 10-20 seconds and it will normally work. When it does start working it will keep dispensing water or ice even after the actuator is released. If you push the actuator again and release it, only then will it stop dispensing. The water pressure is good once it starts and it has no trouble making ice. The only steps I've taken is to change the filter. If I must take the front off to fix the problem can you please explain how to do this without breaking the facing.
That is part of a full model#. I found:
FRS26ZNHB0 FRS26ZNHB1 FRS26ZNHB2 FRS26ZNHB5 FRS26ZNHD0
FRS26ZNHD1 FRS26ZNHD2 FRS26ZNHD5 FRS26ZNHQ5 FRS26ZNHW0 FRS26ZNHW5
Jeff, to you believe part 7 is the one that's bad? Also, looks like I need to take this apart from the front and not through the rear of the door. Any tips on removal?
Ordered micro switch (item 7 on diagram) and this fixed the problem. One of these 2 switches was sticking just enough to keep it from turning off. Jeff, thanks for the help.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
