Frigidaire water dispenser - slow flow
Hi there,
The water flow through the dispenser on my Frigidaire side-by-side (model number: FRS20ZRG) slowed to a tiny trickle after I replaced the water filter recently. The ice dispenser works just fine. When I remove the water filter cover inside the refrigerator and press the dispenser button, water shoots down so I know it's getting that far. I know you have to wait patiently to clear the air from the lines...I've cycled through that process at least a dozen times, so I'm pretty sure it's more than that. My guess is there is some type of blockage between water filter housing and the dispenser...is there a way to clear the lines without disassembling the entire unit? Any other ideas? Thanks.
