Frigidaire Water Dispenser Does Not Work - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2007, 11:10 PM   #1
Frigidaire water dispenser does not work
Hi there,
Hoping to avoid a service call on what must be an easy fix. The water dispenser on my Frigidaire side-by-side (model number: FRS26RLECSO Year: 2004) suddenly stopped dispensing water. A quick visual inspection of the tubes (at the base and back of the unit) indicate no obvious problem. The ice dispenser works. When I remove the water filter cover inside the refridgerator and press the dispenser button, water shoots down so I know it's getting that far. Any clues at all? Thanks so much.
waywestside is offline   Reply With Quote
Old 03-09-2007, 11:16 AM   #2
What was it? I have the exact same problem. Only had the thing for 10 days too...
mscherer is offline   Reply With Quote
Old 03-09-2007, 11:44 AM   #3
I thawed the hoses behind the crispers in the fridge with a hairdryer and that brought the water back. But then I ended up calling a repairman because it stopped again. Problem was a broken fan in the back of the freezer. Wasn't pumping the air through the unit properly. Needed to be replaced. Cost $250.
Old 03-11-2008, 02:45 PM   #4
Sometime when the water dispenser stops working it is the inlet valve at the back of the fridge.
If you do need a part here is a good place to get Frigidaire parts.
girltech is offline   Reply With Quote
Old 09-27-2011, 03:20 PM   #5
Driving me crazy
I have replaced the $130 control panel board, but the water dispenser / ice maker still behaves erratically. Makes a clicking sound, water comes out, then stops, then starts again. Sometimes it just works, but as time goes by, less so.
I emptied the fridge , turned off power for 2 days , after that it worked smoothly for 1-2 hours before starting to mess up again. I made a youtube video to illustrate what exactly the problem is.
I am in a rural area , so its doubtful any one who can repair this would be close by.
Any ideas!?
snapper2k11 is offline   Reply With Quote
Frigidaire Ice/Water Dispenser Metmagic2k Appliances 60 04-18-2011 08:44 PM
Hard water - 37 gpg, .088 iron content. What softener will work? fillys6 Plumbing 9 04-27-2007 10:55 PM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
