Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-10-2010, 10:13 PM   #1
Frigidaire Water Dispenser
I have a Frigidaire refrigerator, model FRS3HF55KS.
The water jet of the water dispenser is becoming increasingly weak
I suppose that inside the device should be a control to adjust this.
How can I open the device and recognize this control to adjust the power of the jet?
Can somebody send me manual?
Dante_sa is offline   Reply With Quote
Old 02-11-2010, 07:55 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
No. As for the manual, it should be online at the manufacturers website. You may have to check the line coming from the cold water line that it is attached to, since there may be debris where both interconnect. Is it connected via Saddle valve at the water pipe?
Old 02-11-2010, 09:46 AM   #3
I can not find the technical manual. I only found the user manual and the electrical diagram.
Let me check the entire water path for troubles, but I don't expects for problems here because the ice maker is working fine.
Old 02-11-2010, 12:19 PM   #4
Pay special attention to the water filter for the dispenser if it shows it.
Old 02-11-2010, 10:23 PM   #5
gregzoll's Avatar
Yep, their model uses a PUR water filter. That would be the first place to look, before tubing, which I never thought about that when I looked at the OP post the first time.
Frigidaire refrigerator not getting water mendels Appliances 5 11-25-2009 01:30 PM
refrigerator water dispenser tackley Plumbing 2 07-05-2009 05:49 PM
water not cold from water dispenser leodlion Appliances 3 06-25-2009 09:25 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
frigidaire refrigerator door water dispenser rmarkd Appliances 5 04-02-2008 12:15 AM
