Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-20-2009, 09:30 PM   #1
Default frigidaire water dispenser
My Frigidaire water and ice dispenser stopped all of a sudden when I was
getting water, even the light bulb went off. Neither the ice dispenser nor the water work but the lights work on the inside. Any clues?
leila is offline   Reply With Quote
Old 10-21-2009, 01:13 PM   #2
J. V.'s Avatar
Is it making ice?
Old 10-21-2009, 01:44 PM   #3
Default rigidaire water dispenser
yes, it is making ice and I also checked the light bulb somewhere else
and it is good. Could it be the motor in the door that somehow dispenses
water and ice? The fridge is 10 yrs. old. Thank you.
Old 10-22-2009, 01:06 AM   #4
First open the freezer door and push the light switch in with your finger. Make sure the interior light goes out. If it does not, the switch is bad.
With the light switch pushed in reach around to the dispenser and see if it now works. This would indicate the door is not properly closing or the switch is going bad.
Next there should be a wire harness connector passing through the top or bottom hinge. Remove the hinge covers and check that it did not come loose. If it is still connected tight, diagnosis will get a bit more complicated.
Model#?
TReally is offline   Reply With Quote
Old 10-22-2009, 04:47 PM   #5
Default Frigidaire water dispenser
The Frigidaire Model No. is FRS24ZSGB1. I tried pushing in the lights but the
dispenser would not work. Also, tried to unscrew the black cover in front of
the refrigerator where you get the ice and water and does not come off.
I do not see any wire harness connector or the top or bottom hinge...???
Everything is pretty sealed.
When I was getting water, it stopped all of a sudden with no noise or anything and the light outside of the dispenser also stopped working.
I have a feeling something is wrong in the door itself. Everything else works!
Any other ideas?
Old 10-22-2009, 05:46 PM   #6
Yoyizit's Avatar
Originally Posted by leila View Post
Any other ideas?
Post a photo of the schematic; it may be hidden somewhere on the back of a panel.
We can step you through the troubleshooting.
You'll probably need a DVM.
These guys
http://www.google.com/search?client=...UTF-8&oe=UTF-8
sell RepairMaster books for just this purpose.
Old 10-22-2009, 10:31 PM   #7
Your model has a wire harness passing through the bottom freezer door hinge, the connector would be just behind the grill cover under the freezer. It also looks like your dispenser is controlled by micro switches, which could be cheaper to fix than electronic units. Looking at your wiring diagram, if all dispenser functions stopped working it would have to be a L1 or neutral problem. You will need a volt/ohm meter for further testing.
Old 10-22-2009, 10:31 PM   #8
Old 10-22-2009, 11:12 PM   #9
Yoyizit's Avatar
Originally Posted by TReally View Post
Maybe the "safety switch" just to the left of center in the diagram has failed to an open circuit?
Old 10-23-2009, 08:29 AM   #10
Usually the door light switch is a no/nc interlock switch, but it looks like this model may have 2 separate switches next to each other in the freezer.
Try and push the "other" switch, and test the dispenser as I mentioned eariler.
Old 10-23-2009, 12:00 PM   #11
Default Water dispenser - Frigidaire
Thank you for all your help but I guess it got too technical for me
and probably need to have someone come in and check it out.
I am at a loss, even though it would seem simple. I tried the light switches, but that doesn't work. Somehow water and/or ice doesn't go thru the dispenser.
More On This Topic
Door handing refers to the way a door opens. Determine the door hand by figuring out whether the door opens inward or outward, and to the left or to the right. You need to know the hand of the door in order to purchase and install the right door hardware... Read More »
Hello, welcome to Expert Village. My name is Wayne Petersen, director of the Massachusetts Audubon Society Important Bird Areas Program and we’re here this afternoon at the Daniel Webster Wildlife Sanctuary in Marshville, Massachusetts. Next we... Read More »
How to Mime Opening Doors
How to Mime Opening Doors by Expert Village
Hi! My name is Teri Lynne and I'm here on behalf of Expert Village. In this segment we are going to show you how to open a few different types of mime doors. So you want to picture the door in front of you. The height, how heavy the door is where the... Read More »
Anyone with a disability wants to feel as though they have full access to their home. In reality, most homes aren't designed for a wheelchair or even a walker. Fortunately, there are several steps you can take to modify your home to improve your... Read More »
Before removing the existing switch, you must first turn off the electrical power to the circuit involved. If you are really lucky, the circuits will be marked accurately. Most likely though you will have to turn a few breakers on and off until you find... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
Frigidare Side-By-side water dispenser kennethkbradford Appliances 2 12-22-2008 10:19 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 01:31 AM
frigidaire refrigerator door water dispenser rmarkd Appliances 5 04-02-2008 01:15 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
