Hi all,
I have a Frigidaire GLGT1031CS1 Laundry Center. We have been doing laundry for most of the day, but when we put our last load in and set the dial we have no water at all running into the machine. There have been occasions in the past when the water supply lines have frozen or screens in the hoses have become clogged that water did not run but you could hear a buzzing noise like it was trying. This is just plain silence.
Water on
Power applied
Only cold hooked up, temp selector on proper temp
I am not sure if I am dealing with a bad rotary switch (other events such as spin are working normally) or if I am having pump problems. The only pump I see in diagrams is the drain pump, does this control filling also.
I have done dryers, furnaces and several other diy projects, but never a washer. Please forgive my cluelessness on their basic operation. Any help and/ or explanations that would point me in the proper direction would be genuinely appreciated!
Thanks,
e1
Water on
Power applied
Thanks,
e1
