Frigidaire Upright Cooling Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 01-02-2013, 03:15 AM   #1
Frigidaire upright cooling issues
About three weeks ago the fan in our freezer started running continuously. The compressor would click on intermittently. There was a noticeable click coming from the compressor area. Unplugging and letting the compressor cool down would remedy the problem for approximately a day. I ordered a new starter from a repair site, after researching that this happens to be a big problem on the fridge model that I have. Replaced the starter and the clicking continues.
After researching some more I pulled the back plate out of the freezer and there was quite a bit of ice build up on the coils. I forced the defrost timer into defrost mode and the heater element heated up right away and melted the ice. The defrost cycle completed and the compressor turned right back on. I then assumed that the defrost timer had failed so I replaced it. It seemed to fix the problem for several days, but now the fridge is doing the same thing it was doing from the get go.
It starts clicking incessantly and doesn't work correctly again until I unplug the unit and let it sit for a while. Putting an ice pack on top of the compressor seems to speed this process up, though that could just be a placebo effect on my end.
I am at my wits end with this thing and ready to replace it, but hate to do so if I have missed something with the troubleshooting. Someone mentioned that there might be something wrong with the starter's capacitor, but it seems like that would just be a stop working all at once type of issue. The compressor runs cold and consistently until the clicking starts. There obviously has to be something wrong with the compressor for this to be happening am I wrong?
Frigidaire FRT18B5JW2
This is more or less identical to my fridge
Michaelpro is offline   Reply With Quote
Old 01-02-2013, 09:00 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
from what I can gather, your problem is the compressor will not start when it is supposed to (the constant clicking)? So your freezer temps are getting way to warm? If this is the case and you already replaced the start relay, your problem is with the compressor itself. It will need to be changed out. Your on borrowed time, you will either have to replace the fridge or the compressor soon.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-02-2013, 02:37 PM   #3
I figured as much. The compressor is getting exceptionally hot. After it runs through the defrost it starts back up, but I assume it is just cooling down enough to do so.
Bummer, the thing is only 3 years old. Guess I will be fridge shopping after work!
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
cooling coil formulas? Tinman_iii HVAC 8 06-05-2009 09:33 PM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 11:46 AM
