-   -   Frigidaire Ultraquiet Iii (http://www.diychatroom.com/f47/frigidaire-ultraquiet-iii-18797/)
mchard 03-21-2008 03:26 PM
Hello
I have had a Frigidaire Ultraquiet III dishwasher for about 4 years and up until now it has been a great machine. But now it will run its complete cycle and will get right before the dry cyle and stop it will continue to run in that place until we manually advance it to the dry cycle. I replaced the timer thinking that was the problem, but I installed the new timer and it does the same thing. It must be a communication problem between the timer and the cycle prior to the dry cycle. I'm about to give up.
Thanks for any help.
jeff1 03-22-2008 09:51 AM
Hi,
These are just names and not a model#.
http://www.applianceaid.com/model.html Some model# helps.
Exact same place each time?
jeff.
mchard 03-22-2008 11:47 PM
exact same spot. it can't be a timer issue.
jeff1 03-23-2008 09:00 AM
Model#?
jeff.
mchard 03-23-2008 10:39 PM
Model # Fdb750rcs0
Thanks For The Help.
Marty
jeff1 03-23-2008 11:45 PM
Fdb750rcs0
Shows a temp boost wash and temp boost rince in the timer motor circuit.
Looks like orange to Yellow one, can try joining the wires together to bypass the stat as a test.
http://www.frigidaire.com/support/Re...&Search=Search ( wire diagram ).
jeff.
yummy mummy 03-24-2008 09:14 AM
I can't help you with your dishwasher but I have a frigidaire dishwasher for 4 years now and I have had to fix it 2 times.
When I fixed it the first time, the guy that came over told me that frigidaire is not known to make really reliable dishwashers. They are pretty cheap he said.
This is the third time that mine has broken down, the panel doesnt seem to be working at all, and I am trashing it because I am not spending any more money on such a cheap product.
So I have gone to Miele this time, double the price but hopefully more reliable.
mchard 03-24-2008 09:36 AM
Jeff-
what will this bypass? Am I just skipping this part of the cycle to see if this is where my problem is? It's been a few years since I've had elementary electronics. Please correct me, but if I connect the orange and yellow and bypass the temp boost rince/wash and the cycle advances onto the dry cycle then my problem would be......thermostat/heating element? But for sure I know my problem is not the timer? Thanks again for the help.
mchard 03-24-2008 09:41 AM
Jeff-
Looking at the cycle chart. It stays running right at the end of the 4th rinse. When a manually advance it through the 4th rinse, then you hear the system drain through the sink and the drying cycle starts.
marty
jeff1 03-24-2008 02:37 PM
**Looks like orange to Yellow one, can try joining the wires together to bypass the stat as a test.**
The rince temp boost thermostat.
Skipping the thermostat yes.
Yes.....but since the boost seems to work ok in the wash the thermostat would be more suspect than the heating element but checking the heating element is still a good idea.
jeff.
ggoodall 03-24-2008 02:37 PM
Timer sticks
My Ultraquiet III (model FDB750RCC0) sticks at two different places in the cycle. If I manually advance the knob one click at each point it will continue on with the cycle. Does this indicate a bad timer or something else?
jeff1 03-24-2008 02:45 PM
Hi,
Might have been better to start a new thread!?
No power ( tested with volt meter ) to the timer motor during one of the sticking modes is something else, power to the timer motor at one of these sticking modes = bad timer.
jeff.
mchard 03-24-2008 04:34 PM
Alright Jeff,
Now what do we have? I put the orange and yellow together and ran it. It worked! What does that mean? My wash thermostat is bad? I wish I would have done this before I spent $100 on a new timer.
Thanks,
Marty
jeff1 03-24-2008 07:36 PM
Since the wash one works but the rince didn't and we had to bypass the rince thermostat, the rince one would indicate to be bad.
I am glad to see we are getting somewhere with the d/w :)
jeff.
mchard 03-24-2008 08:46 PM
okay, I'll order a new rinse thermostat tonight. But which one is that? The part #154290204 or #154227808. I'm assuming the latter. Can I order the part through one of the links under your name? I really appreicate all of your help. One more question. Can I run the dishwasher wired as is? or will that hurt the machine?
Thanks again.
Marty
