Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-21-2010, 02:25 PM   #1
Frigidaire Side by Side Water Actuator snapped off
Model LECR23EFE I've looked at the posts on this problem, I can't get the front of the water/ice area off, I removed the drip tray and took out the screws at the bottom, but the top seems to still be attached, don't want to break anything, are there screws above the lights? if so how do you get to them
Bakerfamily78 is offline   Reply With Quote
Old 10-21-2010, 09:19 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
snaps on, take a little force to remove. pull hard but carefully
hardwareman is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
