Frigidaire Side By Side Problems - Appliances - DIY Chatroom Home Improvement Forum
Old 06-15-2009, 10:55 PM   #1
Frigidaire Side by Side Problems
Model number is GLHS66EEB4. wATER WAS SLOWING DOWN IN THE DISPENSER AND IN THE ICE MACHINE. iT WAS TIME TO CHANGE THE FILTER SO i CHANGED IT OUT AND NOW NOTHING!!! Not a drop. I removed the new filter and noticed the two little white plunger things that plug into the filter and the tip of one has broken off. Is this the problem? Where can I get those parts? thanks.
mw3538 is offline   Reply With Quote
Old 06-29-2009, 02:04 AM   #2
This could be the problem. The plungers need to be depressed for water to flow though the filter. Also I would check the water volume to the valve. The repair is fairly easy, you would need to replace the filter housing. You might try www.appliancepartsdiscount.com
robert1633 is offline   Reply With Quote
can i install amana 1c6 in frigidaire frs22pr ? doitmyselfmom Electrical 2 05-11-2008 12:38 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
Whirlpool side by side icemaker-No Ice wtoler Appliances 2 09-08-2007 10:05 AM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 03:10 PM
