Frigidaire Side By Side Not Dispensing Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 10:12 AM   #1
My Frigidaire Side by Side, Model # GLHS35EHW6 will not dispense ice. It still is making ice and dispenses water. When the lever is pressed, there is no noise. The auger can be turned manually. Any ideas what may be the problem?
Mike_1 is offline   Reply With Quote
Old 04-23-2010, 11:00 AM   #2
Post a schematic.
Old 04-23-2010, 03:19 PM   #3
Sorry, I don't have a schematic.
Old 04-23-2010, 03:35 PM   #4
http://lookup.partadvantage.com/lookup/frigidaire/45296
cellophane is offline   Reply With Quote
Old 04-23-2010, 05:05 PM   #5
It's probably pasted on the back panel, either on the outside or the inside.
By default, I assume it has a motor in series with a lever switch in series with connectors and cabling in series with the power, possibly in series with a fuse, and all these have to be working.
You'll need a VOM or DVM to trace it.
But before you lift a screwdriver check on the price of replacement parts. It may not be worth it to you to fix it, depending on the age of your fridge.
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 06:33 AM
Frigidaire Ice/Water Dispenser Metmagic2k Appliances 60 04-18-2011 07:44 PM
GE side by side JohnJak Appliances 1 09-29-2009 08:41 PM
Kenmore side by side refrigerator not cooling bidderbl Appliances 1 09-26-2009 06:48 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
