#1 |
Frigidaire side by side model # FRS23W3AWE
I just purchased a new house and it came with the above type of fridge. Ice maker works fine but I noticed that water is dispensed very slowly and it is not cold. Isn't the idea of water dispenser to dispense cold water.
I did not get a manual with the appliance documentation and Frigidaire website was not of much help either. Any suggestions? |
#2 |
How long did it sit before being used?
I would start with the water filter if it has one. WE also bought a Whlp this past year. The light came on telling us the filter needed changing. But, I t will work with the filter out. I still have to get a new filter for it, about 40 bucks. |
#3 |
are the cubes full size? if not that could be an indication of filter bad or not enough water to refrig [give you slow dispense]due to tap valve on house line bad. at least 2nd glass should be as cold as food in refrig. make sure original person didn't tap off hot water line [it happens].
| Display Modes | |
| Should I use a vapor barrier on each side? | Hossenfeffer | Building & Construction | 3 | 04-09-2010 11:12 PM |
| Frigidaire Side by Side Problems | mw3538 | Appliances | 1 | 06-29-2009 02:04 AM |
| Side By Side | knottaray | Appliances | 6 | 03-27-2009 09:03 PM |
| Noisy Frigidaire side by side | EZ Rider | Appliances | 7 | 03-12-2008 01:51 PM |
| Side By side refrigerator | Susie Q | Appliances | 6 | 08-31-2007 04:26 PM |
