Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-22-2012, 03:35 PM   #1
Frigidaire side by side freezer works refrigerator doesn't!
I have a frigidaire pure source plus model # frs26zxhd0 side by side. The freezer works great refrigerator is warm. I have opened the back panel on the freezer and coils are frozen. I turned the defrost timer till it turned off. No luck. Still frozen. I checked continuity on the defrost heater and it's good. Put thermostat in ice water and continuity is good. The fan is working fine. I don't know what else to check, compressor seems to be working fine also. Any ideas?
Thank you
Towerdog2 is offline   Reply With Quote
Old 07-22-2012, 05:20 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Thank you
I assume when you turned the defrost timer to the defrost mode you are attempting to check the defrost cycle correct? Did the defrost heaters come on when you did this? You should not have to put the thermostat in ice water to check it, it should already be closed.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-22-2012, 05:23 PM   #3
Yes I was trying to check the defrost cycle. I assume the heater did not come on because it was still iced over. But the heater is showing good continuity?
Old 07-22-2012, 05:25 PM   #4
I unplugged it and let it defrost, plugged it back in and within 2 to 3 hours it's iced over again.
Old 07-22-2012, 07:16 PM   #5
#1 HAWKEYE FAN
is the entire coil frosted over or just a portion of it? If it was completely defrosted there is no way it would be iced up again in a few hours
Old 07-22-2012, 07:19 PM   #6
I guess what I mean is frosted over in a couple hours. Which I suppose is normal. Defrosted it and then in a couple days it iced over again.
Old 07-22-2012, 07:41 PM   #7
#1 HAWKEYE FAN
force a defrost cycle and see if the heater gets hot
Old 07-22-2012, 07:52 PM   #8
I forced a defrost by turning the defrost timer until it turned off the freezer. The heater does not seem to get hot, but when I checked it he continuity it was fine?
Old 07-22-2012, 08:14 PM   #9
#1 HAWKEYE FAN
check defrost thermo for continuity or force defrost then jumper around thermostat.
Old 07-22-2012, 08:27 PM   #10
Continuity is good, any other ideas
Old 07-22-2012, 09:49 PM   #11
#1 HAWKEYE FAN
defrost timer is not advancing on it own, replace it.
Old 07-22-2012, 10:26 PM   #12
#1 HAWKEYE FAN
it may be best to jumper around that defrost thermo before you replace the timer. Try it, see what happens
Kitchen dual switch (only 1 side works)?? jenksthecat Electrical 28 10-25-2011 09:57 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Bang the side of the heater and it works crwalker HVAC 5 03-05-2011 07:56 PM
Frigidaire side by side model # FRS23W3AWE polpep Appliances 2 05-24-2010 07:28 AM
Can I save my Magic Chef Fridge. The Freezer works but the fridge doesn't bmfay10 Appliances 2 03-28-2008 01:54 PM
