Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-07-2009, 07:38 PM   #1
Default Frigidaire refrigerator not getting water
My refrigerator is not getting any water, either to the icemaker or to the freezer door spigot. I check the water valve coming out from the wall and water is getting to the fridge. But it doesn't see to be circulating around it. Any suggestions where it might be stuck. I have not replaced the filter ever, so I took it out completely. But I don't think water is getting up there as well.
mendels is offline   Reply With Quote
Old 11-08-2009, 07:12 AM   #2
you didn't list the model and serial # [ it makes a difference]. it won't work regardless, if the filters out... you probably have bad valve. if you have two & i had to guess, i'd say the single valve.
Jacques is offline   Reply With Quote
Old 11-09-2009, 12:10 PM   #3
The model number is FRS22ZRF. Where is the serial number located?
Old 11-18-2009, 10:25 AM   #4
Household Handyman
The serial number should be located at/near the model number. Most of these are inside the fridge or on a tag at the bottom of the fridge. As stated, you will not get water with the filter out, or IF the filter is not placed properly. Filters must be seated absolutely properly to work. Some are really hard to seat. Water may be getting to the fridge from the valve on the wall, but there is a separate electro-valve for the fridge itself. Some are readily visible on the lower back, some are located behind a panel at the lower back. Some models use this electro-valve, or two separate valves, to control water to both the ice-maker and door water fill. If you have not already, try a new filter. If this doesn't solve the problem, you may have to check out the water fill valve in the back. Good Luck, David
More On This Topic
Hi! I'm Kay and we are filming here at expertvillage.com and we are here at Carter's Appliance in Fontana, California. You may occasionally have to change out the filter. The manufacturer's suggest that you change them out maybe every 6 months to a year... Read More »
The Polaris all-terrain vehicle, or ATV, is a popular brand of four-wheeler. This recreational vehicle allows riders to go off-road to enjoy rougher terrain. The maintenance for these vehicles is very important, though, as riders can find themselves in... Read More »
On behalf of Expert Village my name is Barbara Coradin with Energy Fitness in New York City and today I'm going to show you how to train for a marathon. Just as important as your running for training for a marathon is nutrition. What I like to do is make... Read More »
Hi! I'm Kay and we are filming for expertvillage.com here at Carter's Appliance in Fontana, California. These are typical water filters sold at most appliance stores or readily available at a parts house. This particular model is one that would go... Read More »
This is also full of slides. Maybe I'll pull this all apart. Slides. There's several slides on this instrument and you might even find one that's occasionally stuck especially on older instruments I enjoy finding. I find it really fun to find an old... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 03:02 PM
frigidaire water dispenser problem svao85 Introductions 0 11-08-2008 10:00 AM
Water Actuator Frigidaire PLHS269ZCB3 Nazz300 Appliances 1 03-10-2008 02:43 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 11:03 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
