-   -   Frigidaire Refrigerator Icemaker Problem (http://www.diychatroom.com/f47/frigidaire-refrigerator-icemaker-problem-73104/)
frank ok 06-07-2010 09:17 PM
Frigidaire Refrigerator Model FLSC23F6DSN Icemaker ejector arm makes only one revolution then stops. Will restart on pushing start button, but again makes only one revolution. Water to icemaker is delievered, but ice is not ejected. Freezes solid. Have replaced entire assembly (from Repairclinic.com) but same problem. Water dispenser and filter ok. Ideas? frank ok
branham 06-13-2010 04:23 PM
I removed my ice maker now my ge freezes up in a week, why?
Yoyizit 06-13-2010 06:19 PM
There are jumper wires in the icemaker that disable other necessary circuits in the fridge if you remove the icemaker.
The manuf. does this so you can't have a fridge that fails gracefully, where you lose functions over time.
I don't know if other countries permit the manufacturers of their products to pull tricks like this, but for the US its
http://en.wikipedia.org/wiki/Corporatocracy
Mr. OK, can you post a schematic?
branham 06-13-2010 06:34 PM
ge freezing problem
I'm handy electrically, do you know what jumpers or a fix?I believe the refrigerator is worth repairing. Thanks
Yoyizit 06-13-2010 08:46 PM
If there are two icemaker connector pins wired together that is probably what you should jumper on the mating connector unless there are more booby traps in this thing.
You have a schematic for the icemaker?
branham 06-13-2010 08:57 PM
It isn't legible, but I'm going to do my homework and find one. The refrig and freezer worked fine until I jacked with it, just because the cub
e maker didn't work. Boy she's all over it now! I got to get this thing fixed.
